bradeneuropeArthur
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim c As Sheet
Set c = b.ActiveSheet
Dim d As CustomTable
Set d = c.CustomTables.Item(1)
Dim co As Column
For Each co In d.Columns
co.ValueHorizontalJustification = kAlignTextLeft
Next
End Sub
Arthur Knoors
Autodesk Affiliations:
