dgreatice
in reply to: AlexFielder
Sub createShrinkWrapWithDefinition()
Dim oApp As Application
Dim oAD As AssemblyDocument
Dim oACD As AssemblyComponentDefinition
Set oApp = ThisApplication
Set oAD = oApp.ActiveDocument
Set oACD = oAD.ComponentDefinition
oPath = oAD.FullDocumentName
Dim oPartDoc As PartDocument
Dim oPCD As PartComponentDefinition
Dim ShRDef As ShrinkwrapDefinition
Dim ShrComp As ShrinkwrapComponent
Set oPartDoc = oApp.Documents.Add(kPartDocumentObject, , True)
Set oPCD = oPartDoc.ComponentDefinition
Set ShRDef = oPCD.ReferenceComponents.ShrinkwrapComponents.CreateDefinition(oPath)
ShRDef.ActiveDesignViewRepresentation = "Default"
ShRDef.ActiveLevelOfDetailRepresentation = "Master"
ShRDef.ActivePositionalRepresentation = "Master"
'Call ShRDef.AdditionalExcludedOccurrences.Add(Object) 'Need User Selection
'Call ShRDef.AdditionalIncludedOccurrences.Remove(Object)'Need User Selection
ShRDef.BreakLink = False
ShRDef.CreateIndependentBodiesOnFailedBoolean = True
ShRDef.DeriveStyle = kDeriveAsSingleBodyWithSeams
ShRDef.IsAssociativeDesignView = False
'Call ShRDef.PreservedFeatures.Add(Object) 'Need User Selection
ShRDef.RemoveAllInternalVoids = False
ShRDef.RemoveChamfersDistanceRange = 10 'cm
ShRDef.RemoveChamfersStyle = kShrinkwrapRemoveByRange
ShRDef.RemoveFilletsRadiusRange = 10 'cm
ShRDef.RemoveFilletsStyle = kShrinkwrapRemoveByRange
ShRDef.RemoveHolesDiameterRange = 10 'cm
ShRDef.RemoveHolesStyle = kShrinkwrapRemoveByRange
ShRDef.RemoveInternalParts = False
ShRDef.RemovePartsBySize = True
ShRDef.RemovePartsSize = 10 'cm
ShRDef.RemovePocketsMaxFaceLoopRange = 10 'cm
ShRDef.RemovePocketsStyle = kShrinkwrapRemoveByRange
ShRDef.RenameComponent = True
ShRDef.UseColorOverrideFromSourceComponent = True
Set ShrComp = oPCD.ReferenceComponents.ShrinkwrapComponents.Add(ShRDef)
End Sub
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
