- Mute
- Permalink
- Report
@dgreatice wrote:can you provide video, how you use projection geometry and add geometry in manually process?
@dgreatice Not sure what the purpose is of a video showing how I manually project and how I use it. All of the parts we model are flat parts and if there is a pattern of holes in a part that I need an actual sketch for, I create a sketch and project each hole. Or if it is something I will use multiple times then I will create a sketch and then draw a circle and dimension it so I can create a sketch pattern that matches the hole pattern I created earlier. In any event I am trying to make an automated process that will allow me to reference the feature in iLogic whether it is a shape or a pattern and have the code create the sketch and project the edges of the shape or pattern into the sketch which I use later in a drawing
