06-25-2018
11:08 AM
- Mute
- Permalink
- Report
06-25-2018
11:08 AM
chandra.shekar.g, Thank you for the reply. I was looking for more of an automated approach where user input was not needed. For example in the iLogic code specify which feature (by name) I want to be able to project the edges from and then just have it do a for loop thru and collect all the edges of that feature whether it is a hole, extrude cut or pattern of holes. I was able to project the edges of an extrude if it didn't go completely thru the main body because I could just select the face at the bottom of the extrude cut, where I am have difficulty is when the hole or extrude cut go completely thru the main body then the is no bottom face to pick.
