06-25-2018
12:28 AM
- Mute
- Permalink
- Report
06-25-2018
12:28 AM
Hej hej,
i am trying in VBA to uncheck the "Date checked" box in the iproperties in a drawing and at the same time in its main assembly or main part.
I have the following code that works for the active document itself:
' Get the active document.
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
' Get the PropertySets object.
Dim oPropSets As PropertySets
Set oPropSets = oDoc.PropertySets
' Get the design tracking property set.
Dim oPropSet As PropertySet
'Set oPropSet = oPropSets.Item("Design Tracking Properties")
oPropSets.Item("Design Tracking Properties").Item("Date Checked").Value = "01.01.1601 01:00:00"
Now i am trying to get the main assembly or part from the drawing and change it as well, but i cant get it together...
I found this code that seems to point me in the right direction. I don't need to open the main assembly but change the "date checked" property.
Dim oDwgDoc As DrawingDocument
Set oDwgDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oDrawingView As DrawingView
Dim oModelDoc As Document
For Each oSheet In oDwgDoc.Sheets
oSheet.Activate
Set oDrawingView = oSheet.DrawingViews.Item(1)
Set oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
Call ThisApplication.Documents.Open(oModelDoc.FullDocumentName, True) ' False for invisbly opened
Next
Can anyone help me out with this or point me into the right direction?
