insomnix
1020 Views, 2 Replies
Position Section Line Sketch in Parent View Using iLogic
I am trying to create some automation, but I also want to make it easy for others without much iLogic experience to edit, maintain, and duplicate. There are other threads on how to create a new section view through iLogic, but I want to be able to create the section view manually and place notes, dimensions, symbols, etc.
What I would normally do is right click on the section line and edit; then dimension the line to the part so it would stretch and move with the changes to the part. With the parts I am working on now this method does not work. The part is just a rectangle, but the outside edges have a profile that changes based on the part. When the profile changes, all association with the sketch line edit dimensions are lost.
Below is an example of my normal routine for setting section lines that will dynamically change with the part for section views.
For reasons I don't want to get into, the position of the section view is not centered on purpose. So I have an equation that off centers it.
This gives me a nice predictable section view, until this roundover profile changes to a chamfer. Then these dimensions are all lost.
