- Mute
- Permalink
- Report
Hey guys! Im not sure if this should be posted in the customization forum, mods please move if this is in the wrong spot.
I'm having some weirdness with the "Customize user Commands" window. I have attached a screenshot to help illustrate the issues.
For some reason, when I delete, rename, or move a macro to a different project ivb folder, the old name will still remain on the left side command list. It's getting harder to distinguish the different ones, since most are empty and dont do anything. The current solution is to simply modify the latest macro's name with an underscore_F to signifiy that it is final.
How do I clear this list? I tried deleting stuff from the tools tab-macros function but that only deleted from the actual project, but the name of the macro (that no longer exists) is still present in the customize user commands prompt.
TL;DR- how do I clear the left side column macro list in the attached screenshot? I want to re-load my ivb project afterwards and start over. Its cluttering up and most of them are empty.
kelly.young has embedded your image and edited your subject line for clarity: Customize user command Issues
