Xun.Zhang
Try the sample below via API.
Replace all sub assembly which include Collar.ipt and replace it.
Sub Main()
    'Component.Replace("CollarBottomPlate:1", "Collar.ipt", True)
    Dim doc As AssemblyDocument
    doc = ThisApplication.ActiveDocument
    Dim strFileName As String
    strFileName = "Collar:"
    Dim strPath As String
    strPath = "C:\TEMP\iLogicTest\GA\CollarBottomPlate.ipt"
    Dim oOcc As ComponentOccurrence
    For Each oOcc In doc.ComponentDefinition.Occurrences
        Call ReplaceOccurrence(strFileName, strPath, oOcc)
    Next
End Sub
Sub ReplaceOccurrence(strFileName As String, strPath As String, oOcc As ComponentOccurrence)
    If InStr(oOcc.Name,strFileName)>0 Then
        Call oOcc.Replace(strPath, False)
    End If
    Dim osubOcc As ComponentOccurrence
    If oOcc.SubOccurrences.Count > 0 Then
        For Each osubOcc In oOcc.SubOccurrences
            Call ReplaceOccurrence(strFileName, strPath, osubOcc)
        Next
    End If
End Sub
another example like to replace Collar.ipt in every assembly
Sub Main()
    strFileName = "Collar:1"
    Next
End Sub
    If oOcc.Name = strFileName Then
    End If
        Next
    End If
End Sub
Hope it helps!
Xun
