05-25-2018
08:14 AM
- Mute
- Permalink
- Report
05-25-2018
08:14 AM
It sounds like you're trying to export from an iPart Master file, correct?
This code was meant to peruse all files in an assembly file and find sheet metal flats to export, my quick advice would be insert all of your generated iPart files into an assembly saved in the folder you want the flat exports saved to, then run the code.
Otherwise it's a different code to run through the list iPart Members in a Master file.
