@Anonymous
Does this solve the problem
Public Sub main()
Dim a As inventor.Application
Set a = ThisApplication
If a.Ready Then
'PUT YOUR CODE HERE
Else
MsgBox "Not ready try again"
End If
End Sub
Arthur Knoors
Autodesk Affiliations:
