- Mute
- Permalink
- Report
First of all your sceenshot is based in Vault Basic.
Since Vault basic is very limited this is not easily possible. I have some programming that should be recoded and re-tested with the vault basics.
The step you should make is to implement any other version of vault and this will be an out of the box tool.
The browser you mean is implemented then.
So this is not easy.
Are you familiar with programming?
Are you familiar with the Vault API?
Are you familiar with the inventor API?
If any of these questions is no then dont start programming of Copy it from the forum.
Each release of vault needs to be reprogrammed because of changes in the API.
Arthur Knoors
Autodesk Affiliations:
