- Mute
- Permalink
- Report
Select Multiple Browser Nodes in Drawing
I have code which will find a browser node of a model part in the drawing environment. I then use the following code to turn on hidden lines for the selected node:
'Dim oNode As BrowserNode
oNode.Expanded = True
oNode.DoPreSelect()
oNode.DoSelect()
Dim oControlDef As ControlDefinition
oControlDef = oCommandMgr.ControlDefinitions.Item("DrawingBodyHiddenLinesCtxCmd")
oControlDef.Execute2(True)
This works fine but I have to select one node at time then run the command as '.DoSelect' doesn't appear to allow multiple nodes to be selected.
This is really slowing down my drawing update as I have to show hidden lines for about 30 components (across multiple views).
Is there a way to select multiple nodes at once?
(then I could just run the hidden lines command once)
I tried using SelectSet but could not get this to work ![]()
Any help is greatly appreciated,
thanks,
John
- Mute
- Permalink
- Report
Hoping that below iLogic code would help to select multiple nodes. Before running this code, make sure that selection is made browser node.
Sub Main()
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oTopBrowserNode As BrowserNode
oTopBrowserNode = oDoc.BrowserPanes.ActivePane.TopNode
Dim objColl As ObjectCollection
objColl = ThisApplication.TransientObjects.CreateObjectCollection
Call Get_SelectedNodes(oTopBrowserNode, objColl)
For Each oNode In objColl
oNode.DoPreSelect()
oNode.DoSelect()
oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingBodyHiddenLinesCtxCmd")
Next
End Sub
Sub Get_SelectedNodes(oTopBrowserNode As BrowserNode, ByRef objColl As ObjectCollection)
For Each oNode In oTopBrowserNode.BrowserNodes
If oNode.Selected = True Then
Call objColl.Add(oNode)
ElseIf oNode.BrowserNodes.Count > 0 Then
Call Get_SelectedNodes(oNode, objColl)
End If
Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
- Mute
- Permalink
- Report
Hi Chandra,
thanks for the reply.
Unfortunately this does not help as I'm trying to only run the 'show hidden lines' command once. Using the for loop with the collection does not achieve this.
I'm try to run the command only once as the view seems to regenerate each time it is run, so it is very slow to run it multiple times.
thanks again,
John
- Mute
- Permalink
- Report
As Browser node is entity object, browser node collection can not be added to SelectMultple(EntityColleciton) method. For more details, refer below help documentation on Inventor 2018 API.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-77E546E6-0AA9-4907-B2B4-6946AB500C66
Below iLogic code does the same behavior by selecting individual browser node.
Sub Main()
oNode.DoPreSelect()
oControlDef.Execute2(False)
Call ThisApplication.UserInterfaceManager.DoEvents()
Next
End Sub
End If
Next
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Like".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
