bradeneuropeArthur
Public Sub Main()
Dim a As Application
 a = ThisApplication
Dim b As Document
b = a.ActiveDocument
If b.DocumentType = kAssemblyDocumentObject Then
Dim fi As System.IO.FileInfo
                fi = New System.IO.FileInfo(b.FullFileName)
                If fi.IsReadOnly = True Then
					Exit Sub
				End If
Dim BOM As BOM
 BOM = b.ComponentDefinition.BOM
Try
	BOM.StructuredViewFirstLevelOnly = True
Catch ex As Exception
	MsgBox("Could not BOM stucture FirstLevekOnly")
	'MsgBox (ex.Message)
		End Try
MsgBox (BOM.StructuredViewFirstLevelOnly)
End If
End Sub
Arthur Knoors
Autodesk Affiliations:
