bradeneuropeArthur
like this:
Version:1.0 StartHTML:00000145 EndHTML:00002714 StartFragment:00000294 EndFragment:00002682 StartSelection:00000294 EndSelection:00000294SyntaxEditor Code Snippet
Public Sub Main()
Dim a As Application
 a = ThisApplication
Dim b As Document
 b = a.ActiveDocument
If b.DocumentType = kAssemblyDocumentObject Then
Dim BOM As BOM
 BOM = b.ComponentDefinition.BOM
Try
	BOM.StructuredViewFirstLevelOnly = True
Catch ex As Exception
	MsgBox("Could not BOM stucture FirstLevekOnly")
	'MsgBox (ex.Message)
		End Try
MsgBox (BOM.StructuredViewFirstLevelOnly)
End If
End Sub
Arthur Knoors
Autodesk Affiliations:
