791 Views, 11 Replies
BOMView.Export method not outputing any file.
Hi
I am trying to export Bom from an assembly using API. on most Assemblies it  works fine but some times method don't generate any output file. if I manually export bom by opening assembly in inventor it works fine but through API its not exporting any file.
I don't get any exception or error just no export file.
I am using External application to launch inventor silently then open document and export BOM.
 here is code I am using to export BOM.
      if (document.DocumentType == DocumentTypeEnum.kAssemblyDocumentObject)
          var assemblyDoc = (AssemblyDocument) document;
          var bom = assemblyDoc.ComponentDefinition.BOM;
          bom.StructuredViewFirstLevelOnly = true;
          bom.StructuredViewEnabled = true;
          if (System.IO.File.Exists(csvTempFilePath)) System.IO.File.Delete(csvTempFilePat);
          var bomView = bom.BOMViews["Structured"];
          bomView.Export(csvTempFilePath, FileFormatEnum.kTextFileTabDelimitedFormat);
Why export don't work for some assemblies any help?
