- Mute
- Permalink
- Report
different versions of a Ilogic component
Hello, I am working with differtent versions of 1 Ilogic component in an assembly. All parts that I replace with database parts works fine.
The problem is in the part that I need to change with a parameter. I have written the next rule. This is to calculate the height of a tube. The problem is that this origin part is the same for al versions and if a make a change in version 1 this also change in version 2.
The ideal rule would be that inventor calculate the height "module_funderingsbuis_hoogte" that I need for this part. Then make a part name HOL0101104125_L_162_mm. So where the height depends on the parameter 162 mm. Then he needs to check in de directory C drive Database Maurice\Onderdelen\Afvoer\Buis\Standpijp_Funderingsbuis if this part already exists . If yes then replace with this part. When no then create this part. Save it and replace with this part.
I hope you understand what I need and you can help me. Thanks in advance
