- Mute
- Permalink
- Report
different versions of a Ilogic component
Hello, I am working with differtent versions of 1 Ilogic component in an assembly. All parts that I replace with database parts works fine.
The problem is in the part that I need to change with a parameter. I have written the next rule. This is to calculate the height of a tube. The problem is that this origin part is the same for al versions and if a make a change in version 1 this also change in version 2.
The ideal rule would be that inventor calculate the height "module_funderingsbuis_hoogte" that I need for this part. Then make a part name HOL0101104125_L_162_mm. So where the height depends on the parameter 162 mm. Then he needs to check in de directory C drive Database Maurice\Onderdelen\Afvoer\Buis\Standpijp_Funderingsbuis if this part already exists . If yes then replace with this part. When no then create this part. Save it and replace with this part.
I hope you understand what I need and you can help me. Thanks in advance
- Mute
- Permalink
- Report
This is the code for the replacement and this works fine
SyntaxEditor Code Snippet
HOL0103206125 = "C:\Database Maurice\Onderdelen\Afvoer\Bocht\HOL0103206125.ipt" HOL0103106125 = "C:\Database Maurice\Onderdelen\Afvoer\Bocht\HOL0103106125.ipt" HOL0103292125 = "C:\Database Maurice\Onderdelen\Afvoer\Overschuifmof\HOL0103292125.ipt" HOL0103603160 = "C:\Database Maurice\Onderdelen\Afvoer\Verloop\HOL0103603160.ipt" HOL0103606500 = "C:\Database Maurice\Onderdelen\Afvoer\Knevelinlaat\HOL0103606500.ipt" HOL0108670125 = "C:\Database Maurice\Onderdelen\Afvoer\Diverse\HOL0108670125.ipt" HOL0101104125_L_124_mm = "C:\Database Maurice\Onderdelen\Afvoer\Buis\Standpijp_Koppelbuis\HOL0101104125_L_124_mm.ipt" HOL0103206160 = "C:\Database Maurice\Onderdelen\Afvoer\Bocht\HOL0103206160.ipt" HOL0103106160 = "C:\Database Maurice\Onderdelen\Afvoer\Bocht\HOL0103106160.ipt" HOL0103292160 = "C:\Database Maurice\Onderdelen\Afvoer\Overschuifmof\HOL0103292160.ipt" HOL0108670160 = "C:\Database Maurice\Onderdelen\Afvoer\Diverse\HOL0108670160.ipt" HOL0101104160_L_146_mm = "C:\Database Maurice\Onderdelen\Afvoer\Buis\Standpijp_Koppelbuis\HOL0101104160_L_146_mm.ipt" If Parameter("module_standpijp_diameter") = 125 Then Component.Replace("Overschuifmof", HOL0103292125, True) Component.Replace("Ophangbeugel", HOL0108670125, True) Component.Replace("Standpijp_Koppelbuis", HOL0101104125_L_124_mm, True) ElseIf Parameter("module_standpijp_diameter") = 160 Then Component.Replace("Overschuifmof", HOL0103292160, True) Component.Replace("Ophangbeugel", HOL0108670160, True) Component.Replace("Standpijp_Koppelbuis", HOL0101104160_L_146_mm, True) End If
- Mute
- Permalink
- Report
Select Case Parameter("module_keuze_gebogen_recht") Case 0 ul Select Case Parameter("module_standpijp_diameter") Case 125 Select Case Parameter("module_afvoerbuis_diameter") Case 200 module_funderingsbuis_hoogte = (module_voet_hoogte + module_graafpeil) - (module_afvoerbuis_diameter + 321 + module_mof_hoogte + 71) Case 250 module_funderingsbuis_hoogte = (module_voet_hoogte + module_graafpeil) - (module_afvoerbuis_diameter + 332 + module_mof_hoogte + 71) Case 315 module_funderingsbuis_hoogte = (module_voet_hoogte + module_graafpeil) - (module_afvoerbuis_diameter + 339 + module_mof_hoogte + 71) Case 400 module_funderingsbuis_hoogte = (module_voet_hoogte + module_graafpeil) - (module_afvoerbuis_diameter + 344 + module_mof_hoogte + 71) Case 500 module_funderingsbuis_hoogte = (module_voet_hoogte + module_graafpeil) - (module_afvoerbuis_diameter + 467 + module_mof_hoogte + 71) End Select Case 160 module_funderingsbuis_hoogte = (module_voet_hoogte + module_graafpeil) - (module_afvoerbuis_diameter + 388 + module_mof_hoogte + 77) End Select Case 1 ul Select Case Parameter("module_standpijp_diameter") Case 125 Select Case Parameter("module_afvoerbuis_diameter") Case 200 module_funderingsbuis_hoogte = (module_voet_hoogte + module_graafpeil) - (module_afvoerbuis_diameter + 10 + module_mof_hoogte + 71) Case 250 module_funderingsbuis_hoogte = (module_voet_hoogte + module_graafpeil) - (module_afvoerbuis_diameter + 21 + module_mof_hoogte + 71) Case 315 module_funderingsbuis_hoogte = (module_voet_hoogte + module_graafpeil) - (module_afvoerbuis_diameter + 28 + module_mof_hoogte + 71) Case 400 module_funderingsbuis_hoogte = (module_voet_hoogte + module_graafpeil) - (module_afvoerbuis_diameter + 33 + module_mof_hoogte + 71) Case 500 module_funderingsbuis_hoogte = (module_voet_hoogte + module_graafpeil) - (module_afvoerbuis_diameter + 156 + module_mof_hoogte + 71) End Select Case 160 module_funderingsbuis_hoogte = (module_voet_hoogte + module_graafpeil) - (module_afvoerbuis_diameter + 30 + module_mof_hoogte + 77) End Select End Select 'Minimale Funderingspijp If module_funderingsbuis_hoogte <=150 Then MessageBox.Show("Niet mogelijk, selecteer ander graafpeil", "Waarschuwing") End If
