Owner2229
in reply to: andy-axium
You can use a function like this:
Sub Main()
	MultiValue.List("myFinishExt") = ReadValues("I:\Templates 2018\myFinishExt.xlsx", 1, 1, 2, 100)
	MultiValue.List("myFinishInt") = ReadValues("I:\Templates 2018\myFinishInt.xlsx", 1, 1, 2, 100)
	MultiValue.List("myMaterial") = ReadValues("I:\Templates 2018\myMaterial.xlsx", 1, 1, 2, 100)
End Sub
Private Function ReadValues(sExcelPath As String, Sheet As Integer, Column As Integer, StartRow As Integer, EndRow As Integer) As String()
	Dim R() As String
	Try
		Dim Range As Integer = Abs(EndRow - StartRow)
		Redim R(Range)
		Dim oExcel As Object = CreateObject("Excel.Application")
		oExcel.Visible = False
		oExcel.DisplayAlerts = False
		Dim oWB As Object = oExcel.Workbooks.Open(sExcelPath)
		Dim oWS As Object = oWB.Sheets(Sheet)
		oWS.Activate()
		Dim j As Integer = 0
		For i As Integer = StartRow To EndRow
			R(j) = oWS.Cells(i, Column).Value
			j += 1
		Next
		oWB.Close (True)
		oExcel.Quit()
		oExcel = Nothing
	Catch
	End Try
	Return R
End Function
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
