- Mute
- Permalink
- Report
This is part of the ilogic code below to add custom iproperties and user defined parameters from arraylists to a part and the missing ilogic is to add iproperties and parameters when document is an assembly (traverse and use recursive function to add them to everything in structure)..
The problem is when the rule is ran the hour glass doesn't stop and I have to close inventor down to stop the rule or the fact that inventor has stopped responding... What is my error or errors????
Code Below:
Version:1.0 StartHTML:00000145 EndHTML:00023623 StartFragment:00000294 EndFragment:00023591 StartSelection:00000294 EndSelection:00000294SyntaxEditor Code Snippet
'Check if Active Document is not a Part/Assembly File oDoc = ThisDoc.Document If oDoc.DocumentType = kDrawingDocumentObject Then MessageBox.Show("This Rule Can Only Be Run In Part and Assembly Files!") Return End If ' Check if Active Document is a Part File If oDoc.DocumentType = kPartDocumentObject Then 'Define List of Custom Properties Dim MyArrayList As New ArrayList MyArrayList.Add("1A. NOUN") MyArrayList.Add("1B. 1ST-MOD") MyArrayList.Add("1C. 2ND-MOD") MyArrayList.Add("1D. DESCR") MyArrayList.Add("1E. MATERIAL") MyArrayList.Add("1F. BEND NOTES") MyArrayList.Add("1G. REVISION LETTER") MyArrayList.Add("1H. DESIGN STATUS") MyArrayList.Add("1H. PROVIDE CODE") MyArrayList.Add("1H. UoM") MyArrayList.Add("1I. PREP ID") MyArrayList.Add("ID BEND") MyArrayList.Add("ID EPOXY") MyArrayList.Add("ID HEAT SHRINK") MyArrayList.Add("ID INSERT") MyArrayList.Add("ID MANU. NOTES") MyArrayList.Add("ID PAINT") MyArrayList.Add("ID RIVET NUT") MyArrayList.Add("ID WELD") MyArrayList.Add("2. STANDARD NAME ID") MyArrayList.Add("2A. PART MAIN GROUP") MyArrayList.Add("2B. PART CLASS ID") MyArrayList.Add("2C. TECHNICAL CLASS ID (PART)") MyArrayList.Add("2D. TECHNICAL CLASS ID (ASSY)") MyArrayList.Add("2E. TECHNICAL CLASS ID (VNDR)") MyArrayList.Add("2F. TECHNICAL CLASS ID") MyArrayList.Add("3. MANUFACTURER NO") MyArrayList.Add("3A. MANUFACTURER'S PART NO") MyArrayList.Add("4. RAW MATERIAL") MyArrayList.Add("4A. LENGTH") MyArrayList.Add("4B. WIDTH") MyArrayList.Add("4C. AREA OF PART") MyArrayList.Add("4C. WEIGHT") MyArrayList.Add("ENGINEERING DESIGN GROUP") 'Define List of Custom Parameters Dim MyParamList As New ArrayList MyParamList.Add("StdName") MyParamList.Add("PartClass") MyParamList.Add("PartMainGroup") MyParamList.Add("TechClass") MyParamList.Add("PCode") MyParamList.Add("UoM") MyParamList.Add("RawMaterial") MyParamList.Add("BendNotes") MyParamList.Add("PrepId") MyParamList.Add("SheetMetalStyle") MyParamList.Add("EngApprover") MyParamList.Add("BEND") MyParamList.Add("EPOXY") MyParamList.Add("INSERT") MyParamList.Add("MFRNOTE") MyParamList.Add("PAINT") MyParamList.Add("RIVNUT") MyParamList.Add("HSINK") MyParamList.Add("WELD") MyParamList.Add("NOUN") MyParamList.Add("F_MOD") MyParamList.Add("S_MOD") MyParamList.Add("ENABLE") 'Define Custom Property Collection (ALL) oCustomPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties") Dim oCustProp As Inventor.Property Dim i As Integer 'Dim oString As Object 'Look at Each Property in The Collection For Each oCustProp In oCustomPropertySet 'Check Property Name Against the List If MyArrayList.Contains(oCustProp.name) Then 'Skip It Else 'Delete Custom Properties oCustProp.Delete End If Next 'Look at Each Value in ArrayList For i = 0 To MyArrayList.Count - 1 'Check List Against Properties For Each oCustProp In oCustomPropertySet If oCustProp.Name = MyArrayList.Item(i) Then 'Skip It Else 'Add Custom iProperties From List oCustomPropertySet.Add("", MyArrayList.Item(i)) End If Next Next 'Define User Parameter Collection (ALL) oUserParamSet = oDoc.ComponentDefinition.Parameters.UserParameters Dim oUserParam As UserParameter 'Look at Each Parameter in the User Parameter Collection 'Look at Each Value in ArrayList For i = 0 To MyParamList.Count - 1 'Check List Against Properties For Each oUserParam In oUserParamSet If oUserParam.Name = MyParamList.Item(i) Then 'Skip It Else 'Add Custom iProperties From List oUserParamSet.AddByValue(MyParamList.Item(i), "", UnitsTypeEnum.kTextUnits) End If Next Next 'Set Boolean Value 'Dim Boolean1 As Boolean 'Boolean1 = False 'Set Sheet Metal Style Variable SM = SheetMetal.GetActiveStyle() 'Set Custom iProperties Values iProperties.Value("Custom", "ENGINEERING DESIGN GROUP") = "1510" 'Set Custom Parameter Values MultiValue.SetList("ENABLE", True, False) MultiValue.SetList("BEND", "Y", "N") MultiValue.SetList("EPOXY", "Y", "N") MultiValue.SetList("INSERT", "Y", "N") MultiValue.SetList("MFRNOTE", "Y", "N") MultiValue.SetList("PAINT", "Y", "N") MultiValue.SetList("RIVNUT", "Y", "N") MultiValue.SetList("HSINK", "Y", "N") MultiValue.SetList("WELD", "Y", "N") MultiValue.SetList("UoM", "EA", "in", "in2") MultiValue.SetList("PartMainGroup", "PEP-MAKE", "PEP-BUY") MultiValue.SetList("PCode", "Make", "Buy") MultiValue.SetList("EngApprover", "ENGR", "DIR", "MGR", "ABE", "N/A") MultiValue.SetList("BendNotes", "NO BENDS", "BEND AS INDICATED", "BEND AS INDICATED, FORM 1 AS SHOWN AND 1 OPPOSITE", "ALL BENDS DOWN 90", "ALL BENDS DOWN 90, FORM 1 AS SHOWN AND 1 OPPOSITE", "BEND DOWN 90 EXCEPT WHERE NOTED OTHERWISE", "BEND DOWN 90 EXCEPT WHERE NOTED OTHERWISE, FORM 1 AS SHOWN AND 1 OPPOSITE", "ALL BENDS UP 90", "ALL BENDS UP 90, FORM 1 AS SHOWN AND 1 OPPOSITE", "BEND UP 90 EXCEPT WHERE NOTED OTHERWISE", "BEND UP 90 EXCEPT WHERE NOTED OTHERWISE, FORM 1 AS SHOWN AND 1 OPPOSITE") oUserParamSet.AddByValue("StdName", "PEP-ME", UnitsTypeEnum.kTextUnits) oUserParamSet.AddByValue("SheetMetalStyle", SM, UnitsTypeEnum.kTextUnits) 'Update File RuleParametersOutput() InventorVb.DocumentUpdate() MessageBox.Show("All Properties have been Added to All Part(s)", "iLogic")
- Mute
- Permalink
- Report
I found the solution for anyone interested or experiencing similar issues..
Reference solution below by Curtis W.
