bradeneuropeArthur
1. Open the files you have selected individually.
2. Than run the command for each file and close it again
ThisApplication.CommandManager.ControlDefinitions.Item("VaultPropertyWriteBack").Execute
Or
1. uncheck the children in the dialog box
Arthur Knoors
Autodesk Affiliations:
