553 Views, 2 Replies
Run ilogic script of saving of IPT file.
Hi all!
I have an I-Logic script that i need to run when I save a IPT. so i added the trigger "before save" for the ipt. Problem is, that when I save an IAM, it obviously saves all the changed IPTs too, and runs the script. I would need to limit it to ONLY saving of a single IPT file. Is there a way to do this?
Thanks!
bradeneuropeArthur
please upload your code.
We need to investigate the coding of mistakes regarding the update of the children.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Autodesk Affiliations:
MechMachineMan
Add something like this before the rest of the code in your rule:
Dim oDoc AS Document
oDoc = ThisDoc.Document
Dim boolVis as Boolean
boolVis = False
For Each oVisDoc in ThisApplication.Documents.VisibleDocuments
    If oVisDoc.Equals(oDoc) Then
        boolVis = True
    End if
Next
If boolVis = False Then
    Exit Sub
End if
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
