- Mute
- Permalink
- Report
Sync file properties with vault in ilogic
Hi All!
I have a IAM that contains several IPTs.
when i save, i would like to sync the properties of only the IPTs that are beeing saved. So i encapsulated following code in a file type check. So when i save the IAM it also saves the ipts inside, and if the file that is being saved is an IPT it runs following line:
SyntaxEditor Code Snippet
ThisApplication.CommandManager.ControlDefinitions.Item("VaultPropertyWriteBack").Execute
Unfortunately, even if called while it is saving the IPT of a iam, the above line is executed over the entire iam. Is there a way to selectively sync only single files?
Thanks!
- Mute
- Permalink
- Report
1. Open the files you have selected individually.
2. Than run the command for each file and close it again
Or
1. uncheck the children in the dialog box
Arthur Knoors
Autodesk Affiliations:
