KenVaessen
399 Views, 1 Reply
Rule for Component enable true or false
This is my first post on this Forum. Can somebody help me with this Rule. I want the Part "Verloop" Enabled if
If Parameter("MASTER", "standpijp_diameter") = 125
and I want this function off if I chose Else.
This is what I've got so far
SyntaxEditor Code Snippet
If Parameter("MASTER", "standpijp_diameter") = 125 Then
    Component.Visible("Verloop") = True
    Component.InventorComponent("Verloop").BOMStructure = BOMStructureEnum.kDefaultBOMStructure  'Sets BOM Structure to Default (Includes on BOM)
    Constraint.IsActive("Mate:13") = True
    Constraint.IsActive("Flush:23") = True
    Constraint.IsActive("Mate:14") = True
    Constraint.IsActive("Mate:15") = True
    Constraint.IsActive("Flush:24") = True
    Constraint.IsActive("Flush:26") = False
    Constraint.IsActive("Mate:19") = False
Else
    Component.Visible("Verloop") = False
    Component.InventorComponent("Verloop").BOMStructure = BOMStructureEnum.kReferenceBOMStructure  'Sets BOM Structure to Reference (Includes on BOM)
    Constraint.IsActive("Mate:13") = False
    Constraint.IsActive("Flush:23") = False
    Constraint.IsActive("Mate:14") = False
    Constraint.IsActive("Mate:15") = False
    Constraint.IsActive("Flush:24") = False
    Constraint.IsActive("Flush:26") = True
    Constraint.IsActive("Mate:19") = True
End If
KenVaessen
in reply to: KenVaessen
I've got it!
    Component.InventorComponent("Verloop").Enabled = True
