04-30-2018
01:43 PM
- Mute
- Permalink
- Report
04-30-2018
01:43 PM
You need to pass the document to your form. But that is not easy in I logic. I prefer to use VBA or better .net. then these issues are solved easily. Like the issue here and modal and modeless forms and all the other benefits. Secondary: believe me it will become easier for you......
Arthur Knoors
Autodesk Affiliations:
