in reply to: chandra.shekar.g
Thanks Chandra,
I have used the "thisdoc.document"  and it still fails in the form. I have added the iProperties "Part Number" to the form as was suggested, and I can see that it doesn't change when going between active documents, it only displays the part number of the drawing the form was opened in.
If i run the iLogic external rules by clicking on them and hitting run rule in any active document the rule always works. The problem still appears to be that the form does not refresh its memory between active documents when it comes to referenced model documents, and creating pdf's calling the pdf addin.
For now I can keep closing and opening the form between active documents.
Regards
Jim
