@RoyWickrama_RWEI,
Hoping that below iLogic code would help to edit user parameter.
Sub Main()
	Dim oSelectedDim As DimensionConstraint
	oSelectedDim = ThisApplication.Commandmanager.Pick(SelectionFilterEnum.kSketchDimConstraintFilter,"Select a dimension to change dimension")
    If oSelectedDim.Parameter.DrivenBy.Count > 0 Then
        Dim oUserParam As UserParameter
        oUserParam = oSelectedDim.Parameter.DrivenBy.Item(1)
        oUserParam.Expression = InputBox("Editing user parameter '" & oUserParam.Name & "'", "Edit user parameter", "10")
    Else
        MsgBox ("Selected dimension is not contianing any user parameter")
    End If
	iLogicVb.UpdateWhenDone = True
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
