04-27-2018
07:13 AM
- Mute
- Permalink
- Report
04-27-2018
07:13 AM
okay so the previous code is working now. Why I don't know, restarted my computer and now it works.
But this code is not working.
It was about two weeks ago. Its suppose to print pdfs from the assembly level. Runs through the end but never makes any pdfs
SyntaxEditor Code Snippet
Sub Main() 'check that the active document is an assembly file If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then MessageBox.Show("Please run this rule from the assembly file.", "iLogic") Exit Sub End If 'define the active document as an assembly file Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4) 'get user input RUsure = MessageBox.Show ( _ "This will create a PDF file for all of the asembly components that have drawings files." _ & vbLf & "This rule expects that the drawing file shares the same name and location as the component." _ & vbLf & " " _ & vbLf & "Are you sure you want to create PDF Drawings for all of the assembly components?" _ & vbLf & "This could take a while.", "iLogic - Batch Output PDFs ",MessageBoxButtons.YesNo) If RUsure = vbNo Then Return Else End If '- - - - - - - - - - - - -PDF setup - - - - - - - - - - - - oPath = ThisDoc.Path PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then 'oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2'oOptions.Value("Custom_End_Sheet") = 4 End If 'get PDF target folder path oFolder = oPath & "\" & oAsmName & " PDF Files" 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If '- - - - - - - - - - - - - '- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -'look at the files referenced by the assembly doc = ThisDoc.Document Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition Dim oBOM As BOM = oAssyDef.BOM oBOM.StructuredViewEnabled = True oBOM.StructuredViewFirstLevelOnly = False Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured") Dim oBOMRow As BOMRow Dim oCompDef As ComponentDefinition For Each oBOMRow In oBOMView.BOMRows If Not oBOMRow.ChildRows Is Nothing Call RecurseBOMRow(oBOMRow, PDFAddIn, oFolder) End If oCompDef = oBOMRow.ComponentDefinitions.Item(1) idwPathName = Left(oCompDef.Document.FullDocumentName, Len(oCompDef.Document.FullDocumentName) - 3) & "idw" 'check to see that the model has a drawing of the same path and name 'MessageBox.Show(idwPathName) If(System.IO.File.Exists(idwPathName)) Then Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.Documents.Open(idwPathName, True) oFileName = Left(oCompDef.Document.DisplayName, Len(oCompDef.Document.DisplayName) -3) 'INSERT RULE HERE iLogicVb.Automation.RunExternalRule(oDrawDoc, "DELETE1") iLogicVb.Automation.RunExternalRule(oDrawDoc, "DELETE2") On Error Resume Next ' if PDF exists and is open or read only, resume next 'Set the PDF target file name oDataMedium.FileName = oFolder & "\" & oFileName & "pdf" 'Write out the PDF Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium) 'close the file oDrawDoc.Close(True) Else 'If the model has no drawing of the same path and name - do nothing End If Next '- - - - - - - - - - - - - Call PrintTopLevel() MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic") 'open the folder where the new ffiles are saved Shell("explorer.exe " & oFolder,vbNormalFocus) End Sub Sub RecurseBOMRow(oBOMRow As BOMRow, PDFAddIn As ApplicationAddIn, oFolder As String) oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium For Each oBOMRow In oBOMRow.ChildRows Dim oCompDef As ComponentDefinition oCompDef = oBOMRow.ComponentDefinitions.Item(1) idwPathName = Left(oCompDef.Document.FullDocumentName, Len(oCompDef.Document.FullDocumentName) - 3) & "idw" 'check to see that the model has a drawing of the same path and name If(System.IO.File.Exists(idwPathName)) Then Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.Documents.Open(idwPathName, True) oFileName = Left(oCompDef.Document.DisplayName, Len(oCompDef.Document.DisplayName) -3) 'INSERT RULE HERE iLogicVb.Automation.RunExternalRule(oDrawDoc, "DELETE1") iLogicVb.Automation.RunExternalRule(oDrawDoc, "DELETE2") 'On Error Resume Next ' if PDF exists and is open or read only, resume next 'Set the PDF target file name oDataMedium.FileName = oFolder & "\" & oFileName & "pdf" 'Write out the PDF Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium) 'close the file oDrawDoc.Close(True) Else 'If the model has no drawing of the same path and name - do nothing End If If Not oBOMRow.ChildRows Is Nothing Call RecurseBOMRow(oBOMRow, PDFAddIn, oFolder) End If Next End Sub '- - - - - - - - - - - - - '- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - - Sub PrintTopLevel() PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oAsmDrawing = Left(ThisApplication.ActiveDocument.FullDocumentName, Len(ThisApplication.ActiveDocument.FullDocumentName) - 3) & "idw" oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmDrawing, True) oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -3) 'write out the PDF for the Top Level Assembly Drawing file On Error Resume Next ' if PDF exists and is open or read only, resume next 'Set the PDF target file name oFolder = "C:\Work\Projects\24000\24373\24373-007-7000 PDF Files" oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & "pdf" 'Write out the PDF Call PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium) 'Close the top level drawing oAsmDrawingDoc.Close End Sub
