2223 Views, 23 Replies
iLogic form not updating between open documents when they become active
Does anyone have this issue.
I have created lots of external iLogic rules and when I manually run any of these rules in any open document they all work fine.
To make things easier I created a global form, with which I can press a button and fire the corresponding iLogic rule.
This works well for all rules in a newly opened drawing, but when I move to another already open drawing certain rules don't work. If I close the form and reopen the form in that already open drawing all the rules work again.
I have the event trigger on "open drawing" to fire a rule which loads the form, so if I only open one drawing at a time I have no problems...less than ideal.
All my code is pretty robust, with "thisapplication.activedocument" and " oDoc.ActiveSheet" etc to look only at the current document
Any suggestions?
Using Inv2018.3
64 bit
