04-18-2018
11:34 AM
- Mute
- Permalink
- Report
04-18-2018
11:34 AM
Constraints.AddMate("Mate:1", Object_A.Name, Orientation_A, Object_B.Name, Orientation_B)
as outlined in the API under ComponentOccurrence as that is (typically) what object type is returned from your pick command with that specific selection filter.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-DE229A99-9860-4501-AF4C-C671D120A2DB
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
