- Mute
- Permalink
- Report
iLogic - Toggle Constraining, Occurance Numbers/Names
Greetings,
What I'm trying to build in Inventor 2019; New Toys so experimenting ![]()
In an assembly enviroment, add 2 different parts, each part has named surfaces 1, 2, 3 for example
Run a Form to Select Part A & Select Part B
Snap Surface 1 from Part A to Surface 1 from Part B
Click again on Part A Then Snap Part B To Surface 2 on Part A
Reverse for Part B
The problem I'm running into atm is, since I want to make this a "General" tool
(So having multiple instances of Part A & Part B)
Are the occurance numbers on the parts, how to transfer those along the code
More specificly how to move from the Selected "Object" to a "String"
Since the Occurance Name does not have an iProperty value, which is annoying
Some Crude Unfinished Code:
SyntaxEditor Code Snippet
Dim Object_A As Object Dim Object_B As Object Dim Orientation_A As Integer Dim Orientation_B As Integer ThisAssembly.BeginManage("Group 1")
' Section To Add Required Parts/Assembly's ... ' Select The Primary & Secondary Snap Parts Object_A = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select The First Component") Object_B = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select The Second Component") ' Code To Get The Selected Object Into 2 Seperate Strings ' ... ' Loop Trough Each Availible Socket Orientation_A = "1" Orientation_B = "1" ' ... ' Create Named Surface To Named Surface Constraints 'Constraints.AddMate("Mate:1", Object_A, Orientation_A, Object_B, Orientation_B) Constraints.AddMate("Mate:1", "Testblok 2:1", Orientation_A, "Testblok 1:1", Orientation_B) ThisAssembly.EndManage("Group 1") RuleParametersOutput() InventorVb.DocumentUpdate() iLogicVb.UpdateWhenDone = True
Anyone who has some suggestions on how to do this? ![]()
Kind Regards,
NVD
