- Mute
- Permalink
- Report
iLogic - Toggle Constraining, Occurance Numbers/Names
Greetings,
What I'm trying to build in Inventor 2019; New Toys so experimenting ![]()
In an assembly enviroment, add 2 different parts, each part has named surfaces 1, 2, 3 for example
Run a Form to Select Part A & Select Part B
Snap Surface 1 from Part A to Surface 1 from Part B
Click again on Part A Then Snap Part B To Surface 2 on Part A
Reverse for Part B
The problem I'm running into atm is, since I want to make this a "General" tool
(So having multiple instances of Part A & Part B)
Are the occurance numbers on the parts, how to transfer those along the code
More specificly how to move from the Selected "Object" to a "String"
Since the Occurance Name does not have an iProperty value, which is annoying
Some Crude Unfinished Code:
SyntaxEditor Code Snippet
Dim Object_A As Object Dim Object_B As Object Dim Orientation_A As Integer Dim Orientation_B As Integer ThisAssembly.BeginManage("Group 1")
' Section To Add Required Parts/Assembly's ... ' Select The Primary & Secondary Snap Parts Object_A = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select The First Component") Object_B = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select The Second Component") ' Code To Get The Selected Object Into 2 Seperate Strings ' ... ' Loop Trough Each Availible Socket Orientation_A = "1" Orientation_B = "1" ' ... ' Create Named Surface To Named Surface Constraints 'Constraints.AddMate("Mate:1", Object_A, Orientation_A, Object_B, Orientation_B) Constraints.AddMate("Mate:1", "Testblok 2:1", Orientation_A, "Testblok 1:1", Orientation_B) ThisAssembly.EndManage("Group 1") RuleParametersOutput() InventorVb.DocumentUpdate() iLogicVb.UpdateWhenDone = True
Anyone who has some suggestions on how to do this? ![]()
Kind Regards,
NVD
- Mute
- Permalink
- Report
Constraints.AddMate("Mate:1", Object_A.Name, Orientation_A, Object_B.Name, Orientation_B)
as outlined in the API under ComponentOccurrence as that is (typically) what object type is returned from your pick command with that specific selection filter.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-DE229A99-9860-4501-AF4C-C671D120A2DB
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
- Mute
- Permalink
- Report
Cheers for the reply,
Object_A.Name inside the Constraints.Addmate() doesn't work and gives and error:
Unable to cast object of type 'System.String' to type 'Autodesk.iLogic.Types.ComponentArgument
But it's easily solved by first defining a string and then inputting that string
So far I've split it up into 3 seperate rules, since it's different uses
The Add a Part/Product Rule currently looks like this: (And works like a charm :))
Dim Item As String Dim Item_Unique_ID As String Dim Item_URL As String Dim Item_Extensie As String Dim Offerte_N As String Dim Materiaal_N As String Dim oAsmCompDef As AssemblyComponentDefinition Dim oOccurrence As ComponentOccurrence If Unique_ID = True Then Offerte_N = Offerte_Nummer Materiaal_N = Materiaal_Nummer Item_Unique_ID = Materiaal_N & " - " Else Offerte_N = "" Materiaal_N = "" Item_Unique_ID = "" End If If Producten = "0000 - Testblok 1" Or Producten = "0000 - Testblok 2" Then Item = Product Item_Extensie = ".ipt" Item_URL = "C:\$Working Folder\Designs\iLogic Testen\" 'Item_URL = "C:\$Working Folder\Designs\" & Product & ".ipt" Else Item = Producten & " Configurator" Item_Extensie = ".iam" Item_URL = "C:\$Working Folder\Designs\iLogic Testen\" 'Item_URL = "C:\$Working Folder\Designs\" & Producten & "\20. 3D Designs\" & Producten & " - Configurator.iam" End If oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition i=0 For Each oOccurrence In oAsmCompDef.Occurrences If Left( oOccurrence.Definition.Document.DisplayName,10 ) = Item Then i=i+1 oOccurrence.Name = Item & " :"+ CStr(i) End If Next Dim oProduct = Components.Add(Item_Unique_ID & Item & " :" & (i + "1"), Item & Item_Extensie) Dim sProduct As String sProduct = oProduct.Name ' Unique Product Save - ONLY Top Level with Parameters ! For full copy of all Parts use the Copy command ! WorkspacePath = ThisDoc.WorkspacePath() WorkspacePathLength = Len(WorkspacePath) PathOnly = ThisDoc.Path DirectoryPath = Strings.Right(PathOnly, PathOnly.Length-WorkspacePathLength) 'Check for the New Save folder and create it if it does not exist If(Not System.IO.Directory.Exists(Item_URL)) Then System.IO.Directory.CreateDirectory(Item_URL) End If Save = MessageBox.Show("Save This Product?", "Save Product?", MessageBoxButtons.YesNoCancel) If Save = vbYes Then part = Component.InventorComponent(sProduct) doc = ThisApplication.Documents.Open(part.Definition.Document.FullDocumentName, False) doc.SaveAs(Item_URL & Item_Unique_ID & Item & ".iam" , True) 'doc.Close() End If
Being able to loop trough and renumber the occurances of identical parts/assemblys is essential
However I also need to do this in my "Constraining Rule" but I can't find a command for this?
So final question on this topic, is there a command to run trough all the Relationships and look for an open "Mate" or "Flush" Occurance Number?
- Mute
- Permalink
- Report
I dont think so.
Yay custom solutions!
- Mute
- Permalink
- Report
Found a solution, while there might not be a command for this;
if you leave the constraint name empty it auto generates the name + occurance number ![]()
Constraints.AddMate("", String_A, Orientation_A, String_B, Orientation_B)
The previous posted code still has a few flaws in it but it has gotten a bit big to post it all now
In the case some1 wants to use it, I recommend replacing the ,10 with a number counted from the new file name
sCharacters = Item_Unique_ID & Item & " :" iString_Length = sCharacters.Length
If Left(oOccurrence.Definition.Document.DisplayName,iString_Length) = Item_Unique_ID & Item Then
Back to my constraining code:
Since the "Named Geometry Surfaces" is new in 2019, I'm assuming there is no way yet to automaticly look up / call / list these except for writing the exact name in a rule?
Or automaticly count the number of Surfaces on the part level and put it into a Parameter?
- Mute
- Permalink
- Report
THANK YOU SO MUCH for pointing out how to solve this nasty little gotcha about assigning it to a string variable before feeding it in. I couldn't for the life of me figure out why it wasn't taking my occurrence name value and I was starting to go crazy. lol.
Thank you, Thank you, Thank you.
