Patrick1323
988 Views, 3 Replies
Inventor 2019: Assign Name, Attribut Set Values
we work currently on Inventor 2018 and will switch to 2020 in one year (can't switch now to Inventor 2019). I'm working on standard parts and want to add the ability to use the "Assign Name" feature in later versions.
"Assign Name" simply adds an attribute set to the surface body, I want to do that in Inventor 2018 with a script.
This attribute set contains two attributes. What I want to know is, how the value of the second attribute is used "EAIAABAAAAB1AAAAAAAAAIAAAAAAAAAA"
I named a bunch of elements and wrote down the values, there are basically three different values. The last one is basically the first and the second.
1: EAIAABAAAAB1AAAAAAAAAIAAAAAAAAAA
2: EAIAABAAAADqAAAAAAAAAIAAAAAAAAAA
3: EAIAABAAAAB1AAAAAAAAAIAAAAAAAAAA EAIAABAAAADqAAAAAAAAAIAAAAAAAAAA
When do I need to set the first, second or third one? Are there other values?
Patrick
