- Mute
- Permalink
- Report
I have been messing with the attached code I found on the forum. I am trying to have it go through each sheet and change each balloon to a particular style. For some reason, when I run this rule, it gives me the following error:
Error in rule: Balloon Standard Update, in document: 0002-19-32793.idw
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
My limited programming knowledge is getting in the way of me understanding where the issue lies. It seems to be in this line:
oBalloon.Style = oStyles.BalloonStyles.Item("Stylename")Any idea where it has gone wrong?
I have made sure my style name matches what is in the rule, but that does not seem to be the issue.
Here is the code I am messing with. It cam from @salariua here: https://forums.autodesk.com/t5/inventor-customization/how-to-change-balloon-style/m-p/6415051
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oStyles As DrawingStylesManager
oStyles = oDrawDoc.StylesManager
Dim oActiveSheet As Sheet
oActiveSheet = oDrawDoc.ActiveSheet
'process all sheets
For Each oSheets In oDrawDoc.Sheets
' Iterate over each balloon on the sheet.
For Each oBalloon In oActiveSheet.Balloons
Next
Next
