MechMachineMan
Something like this should accomplish what you want...
Sub Main()
    Dim oDoc As Document
    oDoc = ThisDoc.Document
    BatchQTY = InputBox("Enter Batch QTY", "Batch QTY", 10)
    oBatchQTYCol = 5
    oCurrentQTYCol = 4
    For Each oSheet in oDoc.Sheets
        For Each oPL in oSheet.PartsLists
            Call ClearPLCol(oPL, oBatchQTYCol)
            Call BatchPL(oPL, oCurrentQTYCol, oBatchQTYCol, BatchQTY)
        Next
    Next
    MsgBox("Done")
End Sub
Sub ClearPLCol(oPL As PartsList, oCol As Integer)
    For Each oRow in oPL.PartsListRows
        oRow.Item(oCol).Value = ""
    Next
End Sub
Sub BatchPL(oPL As PartsList, oCurrentQTYCol As Integer, oBatchQTYCol As Integer, oBatchQTY As String)
  On Error GoTo ErrHandler
        oCurQTY = CINT(oRow.Item(oCurrentQTYCol))
        oRow.Item(oBatchQTYCol).value = oCurQTY*oBatchQTY
    Next
  On Error GoTo 0
  Exit Sub
  ErrHandler:
    MsgBox("Cannot convert row qty into an integer. This rule is not valid with
        non integer quantities")
    On Error GoTo 0
End SUb
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
