jtylerbc
in reply to: MechMachineMan
@MechMachineMan wrote:
Hmm. Weird. I see what you mean.
However, if you go into Application options > Save > Prompt To Save for Recomputable Updates, it will prompt to save, thus "fixing" the issue.
It is strange.  The creator of the rule was aware of the issue when we first introduced it, but for a long time it was just the two of us using it.  So long as that was the case, fixing it wasn't that high of a priority because we knew how to deal with the quirky behavior.
That is interesting.  Not sure I like it as a permanent fix because it's difficult to enforce across the department, but it does seem to solve the issue.  I'm going to suggest it to those currently working on hydraulic projects as an interim solution while continuing to search for a more reliable (less user-dependent) one.
