- Mute
- Permalink
- Report
how to show "conditions" within the (form)... I only want to see certain options
I have some part templates that I wanted to see if there was a way to apply conditions to the form itself. What I am asking is this. I have a template for creating machined parts.
Currently a "Material" is chosen; from that option only certain sizes are available within the "Stock OD" option.
What I'd like to do is set up the form so that the option for "Heat Treat" would not even be visible if the material chosen was not Stainless Steel.
As the form stands currently, the "Heat Treat" is always available... so it's confusing others because they feel they need to chose an option... even if the material they choose was Carbon Steel, Aluminum or Plastic?
Is there a way to apply a condition that if certain materials are chosen, that the "Heat Treat" (label) would not even be visible
- Mute
- Permalink
- Report
Yes.
Please see that autodesk documentation, and the blogs available, such as the one below.
https://synergiscadblog.com/2015/10/14/adaptable-ilogic-form/
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
- Mute
- Permalink
- Report
Thank you, one last question, is there a way to color code either fill or text color for the various Labels or their entries?
- Mute
- Permalink
- Report
Not sure... If there was, it would be through the same window that Enabling Parameter is accessible through.
