MechMachineMan
in reply to: jtylerbc
@jtylerbc
In place editting twice made no difference; all files still want to save and all rules fire appropriately.
Are you on 2018.2.3?
If so, I'm really thinking it's your code or that your even triggers aren't set up quite how you think they are.
To reiterate, here's my structure that works just fine.
Top Asm
- Asm 1 - OnSave runs rule in Asm1 that shows a msgbox
- - Part 1 - OnSave runs rule in Part1 that shows a msgbox
When i edit in place down to part 1, then click return twice, then click save, it prompts for all 3 files to save.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
