04-03-2018
07:26 AM
- Mute
- Permalink
- Report
04-03-2018
07:26 AM
It's possible it's something in your code that's causing it to skip.
I just made a dummy assembly with a top level. In a sub-assembly I added a message box on save to the sub-assembly.
I did an in place edit on the sub-assembly, quickly changed some model geometry, then returned to top level.
After clicking the save button, the save for the sub-assembly was already set to yes. When I pressed okay, it ran the rule appropriately in the sub-assembly.
So it DOESN'T look like it's an issue of the file not dirtying... unless there are specific cases that make it behave oddly.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
