chandra.shekar.g
in reply to: jtylerbc
@jtylerbc,
Try to run below iLogic rule to trigger before saving top assembly. The code triggers rule from subassembly in top assembly.
iLogicVb.RunRule("SubAssembly:1", "ruleName")
For further investigation, can you please provide sample assembly files to test? also steps to trigger the rule.?
Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
