lohithna
496 Views, 4 Replies
how to write override massproperties using macro data from excel
i need to overide the set mass properties in excel file or folder , please help with micro
mcgyvr
in reply to: lohithna
You need to be way more specific than that..
If English is not your native language and thats preventing you from providing sufficient details then please write in your native language and we can use Google translate to attempt to understand what you are asking..
lohithna
in inventor property colum , there is predefined mass properties . but as per my requirement i need to over ride the mass properties using macro .
data will avialble in excel . by entering inpeut folder link in excel and pressing a button this mass properties as to write as per excel data
kelly.young has embedded your image for clarity.
lohithna
any one help on my requirment
MechMachineMan
HI @lohithna
Please attempt solving the problem using the available resources online and post back if you have issues.
There are many guides and blogs out there regarding iLogic and accessing excel using the GoExcel commands.
You should simply be able to use the go excel commands to find the relevant row/field and then write them to the Mass Iproperty - also using the appropriate iLogic commands.
Simplying googling "Autodesk + iLogic + GoExcel" should yield many results.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
