235 Views, 0 Replies
Issue with measure tool
I am trying to create a bit of code in visual studio (VB.Net) that will allow me to select 2 or more parts in an assembly (1 primary and x number of secondary items).
My model tree is:
- Top level assembly
      - PCB Assembly
            - PCB
            - Components
      - PCB Screen 1
      - PCB Screen 2
I am trying to measure the distance between occurrence of the PCB assembly, with each occurrence of the top level assembly
My code is below and errors on the measure line if the first "for... each" loop in included. (e.g. If I pick a PCB (primary) and a screen (secondary) as I assume it's not reading the occurrence correctly.
If I pass the PCB assembly (comp_occ1) to the measure function it works (but just for the PCB occurrence).
Can anyone shed some light on what I'm missing?
Dim asmDoc As Inventor.AssemblyDocument = inventorApp.ActiveDocument ' Active Assembly
Dim oOccs As Inventor.ComponentOccurrences = asmDoc.ComponentDefinition.Occurrences ' Occurrences in active assembly
Dim comp_occ1 As Inventor.ComponentOccurrence ' Primary Occurrence
Dim comp_occ2 As Inventor.ComponentOccurrence 'Second Occurrence
Dim seccomparray As New ArrayList ' Array of all secondary components
Dim cont2 As Inventor.NameValueMap = inventorApp.TransientObjects.CreateNameValueMap ' Used for measure command
Dim distance2 As Double
Dim SubAsmdoc As Inventor.AssemblyDocument
Dim compdef As Inventor.AssemblyComponentDefinition
comp_occ1 = inventorApp.CommandManager.Pick(Inventor.SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select Prmimary Item (E.g. PCB Assy)")
SubAsmdoc = inventorApp.Documents.ItemByName(comp_occ1.ReferencedFileDescriptor.FullFileName)
compdef = SubAsmdoc.ComponentDefinition
While True
comp_occ2 = inventorApp.CommandManager.Pick(Inventor.SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select Secondary Item(s) (E.g. Screen)")
If IsNothing(comp_occ2) Then Exit While
seccomparray.Add(comp_occ2)
End While
For Each occ As Inventor.ComponentOccurrence In SubAsmdoc.ComponentDefinition.Occurrences
For Each seccomp In seccomparray
Try
distance2 = inventorApp.MeasureTools.GetMinimumDistance( _
occ.Name, seccomp, _
Inventor.InferredTypeEnum.kNoInference, _
cont2)
Catch
Gap = "Measure Failed"
End Try
