This is default Vault behavior.
if you are using property-mapping in vault to inventor than you don't need the revision table configuration because you use property mapping form vault.
Disable this and you will solve the problem in the base.
And you will always have static values.
regards
Arthur Knoors
Autodesk Affiliations:
