NSBowser
659 Views, 2 Replies
Refresh After using ScreenUpdating = false/true
For performance, many people suggest disabling ScreenUpdating while your program is running to reduce the overhead of generating the graphics.
Sample Code:
// Initialize
_invApp.ScreenUpdating = false;
// Program Code Here
// Cleanup
_invApp.ScreenUpdating = true;
However, after the program has run, Inventor acts as if it needs a repaint. with changes to the browser not appearing, new document tabs not showing, etc.
I've read a few posts that dance around the topic, with the best suggestion appearing to be Minimize/Maximize the window after the program is done.
Has anyone else found a way to correct this, perhaps with some sort of repaint force or otherwise?
Thanks!
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
