- Mute
- Permalink
- Report
Refresh After using ScreenUpdating = false/true
For performance, many people suggest disabling ScreenUpdating while your program is running to reduce the overhead of generating the graphics.
Sample Code:
// Initialize _invApp.ScreenUpdating = false; // Program Code Here // Cleanup _invApp.ScreenUpdating = true;
However, after the program has run, Inventor acts as if it needs a repaint. with changes to the browser not appearing, new document tabs not showing, etc.
I've read a few posts that dance around the topic, with the best suggestion appearing to be Minimize/Maximize the window after the program is done.
Has anyone else found a way to correct this, perhaps with some sort of repaint force or otherwise?
Thanks!
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
- Mute
- Permalink
- Report
In my case, this is not helping and my browser items become unusable and overlapping to the point that I can't select anything in the browser. A minimize and restore also do not fix the issue.
Anyone else found a solution for this yet?
