cmcconnell
1328 Views, 9 Replies
Make all values in a revision block non static
Hello All,
For some reason, for the last few releases, updating properties from Vault has updated our rev block (we use vault rev blocks) correctly, however, the operation adds the correct values to the rev block and then leaves everything static.
Is there a way to use ilogic to change all of the cells to Not Static?
I have found a snippet (thanks @jdkriek and @cbenner) that will make them all static, but my programming capability does not allow me to reverse it. Smiley Sad
Here is the snippet:
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
' Get the revision table
Dim oRevTable As RevisionTable = oDrawDoc.ActiveSheet.RevisionTables.Item(1)
' Get last row
Dim oRow As RevisionTableRow
oRow = oRevTable.RevisionTableRows.Item(oRevTable.RevisionTableRows.Count)
' Make sure we have the active row
If oRow.IsActiveRow Then
' Go through all columns in that row
For i = 1 To oRevTable.RevisionTableColumns.Count
Dim oCell As RevisionTableCell = oRow.Item(i)
' Set all cells to static
oCell.Text = oCell.Text
Next
End If
Mechanix Design Solutions inc.
wouldn't making them non static mean that the earlier version-lines will get updated to the last revision status?
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
No - they are always static no matter what. In other words, they are a snapshot of what they were when they were current.
cmcconnell
in reply to: cmcconnell
To clarify:
My rev block looks like this:
BeforeBefore
After I un-check Static for all of the cells, it looks like this:
AfterAfter
What I am after is a way to automate un-checking Static for all the cells in a rev block. If that helps...
MechMachineMan
From what I can tell looking at it through the API, there is no direct way to clear the static status of the cells in the Revision table. (neither through an exposed static property, nor through formatted text.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
cmcconnell
in reply to: MechMachineMan
That is what I was afraid of. It looks like it is available for the partslist but not the rev block: https://forums.autodesk.com/t5/inventor-customization/how-to-get-static-value-in-vba/m-p/6980937/hig...
Thanks for looking into it.
Unfortunately, Inventor API does not support "static" property for ReviosionTableCell Object. It would be nice to inform at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
This is default Vault behavior.
if you are using property-mapping in vault to inventor than you don't need the revision table configuration because you use property mapping form vault.
Disable this and you will solve the problem in the base.
And you will always have static values.
regards
Arthur Knoors
Autodesk Affiliations:
maxim.teleguz
found a beautiful way of doing this, you are welcome world.
	Dim oSheet As Sheet
	Dim oRows As RevisionTableRows = oRevTable.RevisionTableRows
	Dim oApp As Inventor.Application = ThisApplication
	Dim UNDO As Transaction = oApp.TransactionManager.StartGlobalTransaction(oDrawDoc, "Remove Static from Revision Table")
	P = iProperties.Value("Project", "Revision Number")
	oRows.Add()
	Dim oRow As RevisionTableRow = oRevTable.RevisionTableRows.Item(oRevTable.RevisionTableRows.Count)
	For Each oRow In oRows
		Else
			oRow.Delete
		End If
	Next
	Dim oCell1 As RevisionTableCell = oRevTable.RevisionTableRows.Item(1).Item(1)
	Dim sFText As String = oCell1.FormattedText
	sFText = P'InputBox("What is the Revision?", "RevisionTableCell.FormattedText", P)
	oCell1.FormattedText = sFText
	c = "REV"
	'just in case it doenst exit recreate it
	Try : x = iProperties.Value("Custom", c) : Catch : iProperties.Value("Custom", c) = "Job number/Reason Code or ECN #" : End Try
	iProperties.Value("Custom", c) = sFText
	iProperties.Value("Project", "Revision Number") = sFText
UNDO.End
