03-27-2018
01:31 AM
- Mute
- Permalink
- Report
03-27-2018
01:31 AM
I suspect that one of your references isn't getting copied locally when you perform a build; the most likely candidate is the "fluentscheduler" reference since everything else I can see is pretty "standard".
To fix this, select it in your references, go to the properties and set "Copy Local" to true.
If that doesn't fix it, there are other things you can try, but I always find one thing at a time is the best approach when debugging this sort of thing.
Alex Fielder
Inventor Expert
https://github.com/alexfielder/
LinkedIn - Github Inventor Extension Server - Bonkers polygon iLogic thing
Top ten iLogic Tips - API Shortcut In Google Chrome - Assembly Extrusion Example
Alex Fielder
Inventor Expert
