basnederveen
in reply to: Thomas.Long
You can debug it. I assume your using the inventor addin template from the sdk? You need to configure the debugging so it starts inventor.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-52422162-1784-4E8F-B495-CDB7BE9987AB
This should describe how to configure ur VS. Im using 2017 and debugging class libraries alot..
