03-26-2018
01:43 PM
- Mute
- Permalink
- Report
03-26-2018
01:43 PM
If I remember correctly, not all plane creation method works. Some wrok in part and some work in assembly. Also what need to be passed are pretty specific type. This took some trial and error so it may not be to best solution.
This is what I use to create point and planes on COG, VS VB.net Inventor addin:
Private Sub COGUpdate()
Dim oWorkPoint As WorkPoint
Dim oWorkPlane As WorkPlane
Dim vX, vY, vZ As UnitVector
Dim oFixedDef As FixedWorkPointDef
Dim oAssPtDef As AssemblyWorkPointDef
Dim PointExist As Boolean = False
Dim COGXYExist As Boolean = False
Dim COGXZExist As Boolean = False
Dim COGYZExist As Boolean = False
Dim oDoc As Document = m_inventorApplication.ActiveDocument
Dim oCenterOfMass As Point = oDoc.ComponentDefinition.MassProperties.CenterOfMass
For Each oWorkPoint In oDoc.ComponentDefinition.WorkPoints
If oWorkPoint.Name = "COG" Then
PointExist = True
If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
oAssPtDef = oWorkPoint.Definition
oAssPtDef.Point = oCenterOfMass
ElseIf oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
oFixedDef = oWorkPoint.Definition
oFixedDef.Point = oCenterOfMass
End If
oDoc.Update()
Exit For
End If
Next
If Not PointExist Then
oWorkPoint = oDoc.ComponentDefinition.WorkPoints.AddFixed(oCenterOfMass)
End If
vX = m_inventorApplication.TransientGeometry.CreateUnitVector(1, 0, 0)
vY = m_inventorApplication.TransientGeometry.CreateUnitVector(0, 1, 0)
vZ = m_inventorApplication.TransientGeometry.CreateUnitVector(0, 0, 1)
For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
Select Case oWorkPlane.Name
Case "COG XY"
oWorkPlane.SetFixed(oWorkPoint.Point, vX, vY)
COGXYExist = True
'oWorkPlane.Delete()
Case "COG XZ"
oWorkPlane.SetFixed(oWorkPoint.Point, vX, vZ)
COGXZExist = True
Case "COG YZ"
oWorkPlane.SetFixed(oWorkPoint.Point, vY, vZ)
COGYZExist = True
Case Else
Exit Select
End Select
Next
If Not COGXYExist Then
oWorkPlane = oDoc.ComponentDefinition.WorkPlanes.AddFixed(oWorkPoint.Point, vX, vY)
oWorkPlane.Name = "COG XY"
End If
oWorkPlane = oDoc.ComponentDefinition.WorkPlanes.AddFixed(oWorkPoint.Point, vX, vZ)
oWorkPlane.Name = "COG XZ"
End If
If Not COGYZExist Then
oWorkPlane = oDoc.ComponentDefinition.WorkPlanes.AddFixed(oWorkPoint.Point, vY, vZ)
oWorkPlane.Name = "COG YZ"
End If
oDoc.Update()
End Sub
