- Mute
- Permalink
- Report
Simplified Situation:
I have an assembly (assyDoc) which contains a UCS in 3D Space, not aligned relative to the origin at all. I would like to create a workplane, such as via AddByPlaneAndPoint, using an Assembly Origin Plane and the UCS Center Point.
What I've Tried:
I've tried using the UCS.origin, which returns a workpoint, but that errors:
var wp1 = workPlanes.AddByPlaneAndPoint(assyYZPlane, UCS.Origin);
I thought maybe the UCS origin and Center Point were not the same thing, so I tried creating a Pt using the 3 UCS planes first, but that also errors:
var centerPt = workPoints.AddByThreePlanes(UCS.XYPlane, UCS.XZPlane, UCS.YZPlane);
It feels to me like I'm missing a proxy aspect the way that it wont create work features in the assembly using the UCS items, however, you can only create proxies (as far as i am aware) using componentOccurrences, which the UCS in the assembly is not. Maybe there is something i am missing that the UCS planes are not really at the same level in the assembly as I am thinking they are, but I see no other way of utilizing them or creating proxies of them.
Thanks for any help!
Nathan
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
