705 Views, 1 Reply
03-21-2018
01:13 AM
- Mute
- Permalink
- Report
03-21-2018
01:13 AM
Hello
the Thumbnail is in IPictureDisp format, and the picturebox requires an image.
How can it be converted?
The sugestion found on the fourms to use VB6 does not seem to work anymore. (removed because obsolete, and not compatible with 64 bit system)
In the addin template there is the image converter that converts from image to IPictureDisp but not the inverse.
Thank you!
